Looking for a running 302
- landshark
Looking to pick up a running 302 can be stock will be used for a buddies 50's Willies project.
Let me know if anyone has one they are looking to part with.
- Moab Mike
Re: Looking for a running 302
I have one from my 76', running good when pulled but had a vacuum leak. I was going to use it for my 74' project until I pulled the 351 trigger.
$200?
$200?
- cpldavis37
I just pulled my 302, It came from a 91 or 92 5.0 mustang gt. It is a builder though and I believe it needs a rebuild. It does have crane lifters on the e7 heads, so someone did some work to it. I would include an msd ignition edlebrock intake.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- cpldavis37
Pic.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- landshark
Moab Mike wrote:I have one from my 76', running good when pulled but had a vacuum leak. I was going to use it for my 74' project until I pulled the 351 trigger.
$200?
Thanks Mike I'll get back to you shortly on it.
- landshark
cpldavis37 wrote:I just pulled my 302, It came from a 91 or 92 5.0 mustang gt. It is a builder though and I believe it needs a rebuild. It does have crane lifters on the e7 heads, so someone did some work to it. I would include an msd ignition edlebrock intake.
I think my friend wants something he can drop in. Will confirm tomorrow.
- cpldavis37
No problem
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- Aztec77Bronco
I have a 302 HO (351 firing order)I was told it ran when I bought the bronco, but the transmission was stolen after a rebuild right before I bought it. I'm doing a power plant swap to either 351 or diesel .
Sent from my SAMSUNG-SM-G870A using Tapatalk
'77 Sport, 302 HO on it's way to a resurrection!
'03 Mercedes CLK 320 Cabriolet (W208 body)
'13 Ford F350 Lariat Crew Cab 4wd Power Stroke
- ImIn4Lo
Landshark, any chance your buddy could use a running 302 that is bolted up to an NP435 and dual Dana 20's? You can come see it all running before I pull it all out .
- ZOSO
- Moderator
Yes^^^^ and add that cold duck to the red bronco.
- ImIn4Lo
The Cold Duck is for sale out of the red Bronco.
If you wana check it out, message me your number and we can meet up.
