What power steering pump Are running?
valentino
So I have a stock power steering pump and I would like to up grade.I would like to know what power steering pump you have,why,where did you get it and any mods you needed to make
- ZOSO
- Moderator
Re: What power steering pump Are running?
- Dirtheadz
Canned ham (Saginaw) off a Lincoln with WTO mod
- Jesus_man
Dirtheadz wrote:Canned ham (Saginaw) off a Lincoln with WTO mod
Same saginaw pump, but with remote res off an Astro Van. Pulled it off the van and bolted it on with finger crossed. That was 9 years ago (but it's been taking a break for the past 4)
- ManTruck
I use the WH pump, which is awesome. I'm locked with Detroit's front and rear and the Wild Horses HD pump is awesome. I had a factory pump, then upgraded to the Sag which worked better, and then went to the WH pump after I put the locker up front and it was a very great improvement over the Saginaw I had. Do it right the first time, get the WH pump.
Owned my 1972 since 1985
Canon City, Co
Canon City, Co
