What did I just see?
Post by Gunnibronco »
I was looking at a junked out dent side 4x4 Ford Econoline.
I saw it had radius arms and was high pinon, and thought I might grab it (free). The radius arm wedges were separate from the knuckles (pre 78 style). Then I noticed it had king pins, not ball joints. Was it a 44 or a 30? Never seen anything like it.
Looked like a D20 and a 9". I was told I could take anything off it I wanted. Would it have a C4 or a C6?
sykanr0ng
Re: What did I just see?
Post by sykanr0ng »
They weren't made by Ford, so it could be built with just about anything.
I found a little bit of info, but not much. Looks like there were kingpin HP D44s put into F100's from about 65-70. The pumpkin was weaker than a ball joint D44. The dent side van body style started in 75.
I believe they were also closed knuckle.
IDK, but what I saw yesterday was open knuckle.
