ZF shifter spring
- Gunnibronco
ZF shifter spring
I need the spring under the shifter top plate for a S5-42 ZF.
- Eck
Re: ZF shifter spring
I came across this site. Maybe call them and tell them what you need. Also- if you don't have it, order the gasket for the shifter (BCB also sells the gasket).
http://www.drivetrain.com/parts_catalog ... l_kit.html
- landshark
if you cant find one, someone down here might be able to pull one off a diesel or 460 ZF in the junk yard, they use the same shifter
- crawlercreations
I replied in your other thread. I'll take a look at my old shifter tonight and let you know. It was fully functional and felt perfect when I pulled it so I am assuming it will work for you. Out of my 460 powered pickup.
