Looking for a set of 4.11 gears for my full width axle swap dana 44, mabey if someone switched and still has the 4.11s available?
Thanks guys
Good set of 4.11 ring and pinnion dana 44 high pinion gear s
rooster
cravenbronco
Re: Good set of 4.11 ring and pinnion dana 44 high pinion ge
rooster wrote:Looking for a set of 4.11 gears for my full width axle swap dana 44, mabey if someone switched and still has the 4.11s available?
Thanks guys
I found spiser gears for 260 and sirra gears for 180
I found that I can get them from On Track Performance,
Tom's Bronco parts and Front Range Driveline
They are costing anywhere from 160 up to 300
I'm in same boat needing 4.09 4.10 or 4.11 gears for my D44 swap
- Gunnibronco
Try Ron's, he seems to have real good package prices. I bought my SD gear & bearings from him, excellent service.
http://www.ronsmachiningservice.net/reverse-rotation/
rooster
Would you ever buy an used set, or would this be a bad idea?
- sykanr0ng
rooster wrote:Would you ever buy an used set, or would this be a bad idea?
Used? But not abused.
Yes.
Inspect carefully, don't buy sight unseen.
- Justin
If you're patient, good deals are out there. My fronts are used, $50 and went in fine. My rear gears I found new in the box off craigslist with the rebuild kit for cheap.
