Stumble stumble
- Rox Crusher
Stumble stumble
My new 351w now has 6000 kick ass miles on it. It runs very nice and I love the sound and feel.
Meanwhile, I continue to have an irritating stumble that I can't solve.
It only happens between 2900 - 3300 rpm. I have a digital tach which I have been watching very close and the stumble is very consistent and predictable within the range I mentioned. I'm not sure stumble is the right word. It's more like a series of dead spots within that range. When it "stumbles" it's kind of like the ignition goes completely dead for a nano-second and then right back to good.
I have good fuel pressure and the spark plugs look good. No codes on the computer either.
I thought it could be dead spots in throttle position sensors but I swapped in my spare tps sensor without solving the problem.
So, let's hear your ideas and recommendations and actions !
- landshark
Re: Stumble stumble
Coyote
horseplay
Re: Stumble stumble
Sounds like a possible pickup sensor
- Rox Crusher
Re: Stumble stumble
horseplay wrote:Sounds like a possible pickup sensor
Cam position sensor ?
- Digger
Re: Stumble stumble
Do you have a Knock Sensor?
- ZOSO
- Moderator
Re: Stumble stumble
Rox Crusher wrote:horseplay wrote:Sounds like a possible pickup sensor
That doesn't do much. But it may be a possibility or the crank position sensor.
- Rox Crusher
Re: Stumble stumble
It's all Explorer stuff.
So no knock sensor that I'm aware of.
horseplay
Re: Stumble stumble
I would check the integrity of all the cam position assembly from connector to drive gear.
- ZOSO
- Moderator
Re: Stumble stumble
these are the same injectors that were on the 302 right? I wonder if you have a bad one somewhere.
- Rox Crusher
Re: Stumble stumble
ZOSO wrote:these are the same injectors that were on the 302 right? I wonder if you have a bad one somewhere.
Nope, this are different injectors. Refurbished 17lbs with returnless rail set up
- ZOSO
- Moderator
Re: Stumble stumble
Rox Crusher wrote:ZOSO wrote:these are the same injectors that were on the 302 right? I wonder if you have a bad one somewhere.
hmm. is it under load or does it do it free revving?
- Rox Crusher
Re: Stumble stumble
ZOSO wrote:Rox Crusher wrote:ZOSO wrote:these are the same injectors that were on the 302 right? I wonder if you have a bad one somewhere.
I believe it does it free revving. I'll confirm it in the morning in front of my Prius neighbor's house
- ZOSO
- Moderator
Re: Stumble stumble
If it does stick a timing light on each plug wire. Then also open the injector harness and do each injector. It should pick it up if it's one of those.
- Rox Crusher
Re: Stumble stumble
Just getting back to planet Bronco after two long weeks of business travel.
I wiggled all the cam position wiring / connectors and problem remains.
Sounds like I need to check gear and then move on to plug wires and injector wires, etc
