Fuel lines & filter
Fuel lines & filter
Any of you come up with a clever solution for the fuel system? I've got a 3/8" steel line in place and am trying to decide between re-using that with 6AN fittings and braided hose or running a new factory nylon line. I've already got a bunch of 6AN fittings, so cost is probably equal. The kicker is that I'd need to come up with a way to set up the fuel filter so that I'm not having to change fittings every time I want to change the filter. Anyone have a compact solution for a spin-on fuel filter (the ones that look like an oil filter)?
Re: Fuel lines & filter
I run steel lines with an compression fittings on each end. Then run ptfe hose. I am running a filter that has an fittings on each end.
Post by Digger »
Do you have pictures of the OEM spin on filter assembly?
I used the inline push-to-connect filter assm with Dorman OE style quick connects. Russells makes Quick disco to AN adapters for interfacing with OE fittings.
I don't have the assembly yet, that's the main thing I'm trying to figure out.
