Is there an app/software that anyone knows about for engine management for an iPad?
Doesn't have to be iPad - they just are off the shelf type hardware and an option.
Similar to a glass cockpit for GA is what I'm looking for.....
Since I'm about to rewire the entire rig - just thought about it.
Erik
Glass cockpit
Unaweep
Glass cockpit
- Digger
Re: Glass cockpit
I don't know of any apps specifically except for Torque, but that can be a little laggy. I don't consider it real-time.
I've looked at these units and similar from Amazon, Flea-bay, etc.
They require OBDII to interface.
There is also the Trail Tech units. While designed for MCs, they could be easily adapted to a truck
Are you looking for an easy way to get gauges or are you really gunning for a glass-cockpit arrangement?
Unaweep
Re: Glass cockpit
Thinking about a glass cockpit. I like the trending information you can get from them.
But since this is a old school Bronco - carb, NP435..I think I'll go with analog style gauges and do a glass cockpit in another Bronco thats got modern stuff..auto trans, EFI, etc...
I may do a engine management system like this as an example:
https://www.aircraftspruce.com/pages/av ... 830jpi.php
- EFI Guy
- VENDOR
Re: Glass cockpit
Easiest and cheapest is probably Torque. But it requires OBD2 and can be slow to update, like approx 1 second refresh rate depending on how many items you log. Which is good enough for everything but Tach.
