Tilt steering install questions
Unaweep
Post by Unaweep »
I have a tilt steering wheel that I'd like to install in my Bronco.
It was part of the truckload of extra parts when purchased.
I think it was from a Mazda...
Any tips or info - I'm going to do it the same time I rewire the Bronco this summer.
Erik
Post by Kinder »
I don't know that column style, the bigger decision points are usually the the depth the column sits at and the connection style. You'll likely need to remove and reuse the mounting flange from your original column. And then decide to reuse the connection style, rag joint, or upgrade to a modern U joint style.
