Harmonic balancer, on all the way?
cpldavis37
Post by cpldavis37 »
I took some pictures, it looks like it should go on further. The pulley lines up with the water pump pulley. What do the experts say?
TJ
F. Scott Fitzgerald
Re: Harmonic balancer, on all the way?
Post by Kinder »
If it lines up then you should be good, I'd check it with the accessory pulleys and call it done.
Post by Viperwolf1 »
Pics don't work for me.
D&D72
Post by D&D72 »
Me either. I think that needs to go in more. doubt your crank sensor would line up.
cpldavis37
Phil can you not see the pics or does it not look right?
TJ
F. Scott Fitzgerald
Can't see the pics on my phone.
