I just installed a new 3-pod gauge on my bronco, so it's finally got a properly reading water temp!! Wow, the old one was clearly not working correctly!
Anywho, I was considering seeing if I can get the factory voltmeter working (perhaps just hooked up??) and then pull the voltmeter from my existing pod and replacing it with a dual fuel pressure gauge so I can monitor fuel pressures after both the LP and HP pumps. Anyone seen such a gauge that isn't outrageously priced? I can only find ones that are north of $250! I'd prefer a 2 1/16" gauge, but I might be able to make something else work.
Also, my thinking is digital would be the easiest to install, but I have heard that the accuracy of some digital gauges are not near as good as analog. But I am wondering if digital would be a cleaner install.
There is the option of installing one on the HP side for now as well, and then perhaps another later, but I'm forever trying to de-clutter my poor bronco!
Dual fuel pressure gauge?
- Jesus_man
