Looking for Stock Manual Pitman Arm
- landshark
Looking to compare the pitman arm I have with a Bronco Stock manual arm. Please let me know if someone has one I can borrow or buy, thanks.
- landshark
Re: Looking for Stock Manual Pitman Arm
Still looking, also looking for a astro van pitman arm as well.. thanks!
- landshark
Phil was nice enough to find a Astro Van pitman arm and will test it out! Thanks.
- Rox Crusher
Chris, what has you looking for shorter pitman arm ?
I think I may have the same issue.
cravenbronco
I'm sure I have a stock one laying around if you still need it
- landshark
Rox Crusher wrote:Chris, what has you looking for shorter pitman arm ?
Two things. First is the drag link DOM slightly hits the tie rod DOM at certain angles. Not bad but enough I think itΓÇÖs putting stress on the rod ends and causing pre mature wear on the treΓÇÖs.
Second. Since I moved my track bar further out and down my angles are off. I either need to drop the track bar at the frame end or raise the pitman arm connection. I think this Astro van pitman arm could solve both. ItΓÇÖs perfectly flat so it will bring my drag up about 1ΓÇ¥ I think.
As a added bonus it might put slightly more turn in my steering. Right now my steering is very touchy because of the 4x4x2 box. ItΓÇÖs not bad but a little more compliance would be nice.
- landshark
appreciate it. Ian going to see if I can make this Astro can arm work first. It will be a while before I can wrench on the bronco.cravenbronco wrote:I'm sure I have a stock one laying around if you still need it
