Heater box
Heater box
Post by mickphatmac »
Im looking for a heater box.
mine leaks like a sieve!
Preferably closer to NorCo than South!
sykanr0ng
Re: Heater box
Post by sykanr0ng »
If nothing closer shows up here's one:
https://denver.craigslist.org/pts/d/66- ... 36788.html
Re: Heater box
sykanr0ng wrote:If nothing closer shows up here's one:
Thanks! I saw that...$100 crazy bucks
phyler
CCB Admin
Re: Heater box
Post by phyler »
Do you just need a new core? Those are only like $20-25. Or is your box cracked due to age?
OG
Re: Heater box
phyler wrote:Do you just need a new core? Those are only like $20-25. Or is your box cracked due to age?
Thanks Phyler, I haven't pulled it out yet, but I do know that ALL my radiator fluid ran out under the passenger seat and out the door before I knew WTF was going on!
Re: Heater box
So $50 bucks total with shipping from WH and Toms $48 JBG.... $26 @ AUTOZONE!
Re: Heater box
Phyler is on the right track. Sounds like core rather than the box. Easy to replace
Sent from my SM-T810 using Tapatalk
Re: Heater box
Post by Gunnibronco »
While you are in there you might as well replace the foam seals.
https://www.wildhorses4x4.com/product/H ... ater_Parts
Re: Heater box
Gunnibronco wrote:While you are in there you might as well replace the foam seals.
ThatΓÇÖs right on point... and while IΓÇÖm there shouldnΓÇÖt I do a motor or squirrel cage upgrade to???.... please, letΓÇÖs not get started a ΓÇ£ while youΓÇÖre thereΓÇ¥ thread! LOL!!!
Re: Heater box
Yes you should. Motor and squirrel cage is $50. The best upgrade you can do to get heat into the bronco.
phyler
CCB Admin
Re: Heater box
Post by phyler »
How do you think my build thread got started? I needed new body mounts so I got there by replacing 50% of the sheet metal. That said, of you are going to replace the core, do whatever else you can to build the box once. It's worth it.
OG
Re: Heater box
You suggested the heater upgrade yourself, not me! LOL.
The squirrel cage and motor make a huge difference, and are way easier when the box is out (ask me how I know). But you don't have to.
I expect that the seal kit/foam pieces inside the box will be toast/dust/non-existent. You probably, actually do need the seal kit or the fan will just pull air around the heater core, instead of through it. And the box won't seal to the firewall and cold air/water will get into the cab where the heater core penetrates the firewall. You'll either have a sub-par performance or spend more time & money trying to cobble the seals together than the kit costs. IMO.
Re: Heater box
You suggested the heater upgrade yourself, not me! LOL.[/quote]
LOL...I was joking...but now seals, etc are on the list!
ps, look what I found in my junk pile from my ΓÇÿ72 build ;)
Re: Heater box
mickphatmac wrote:LOL...I was joking...but now seals, etc are on the list!
You will be time and money ahead.
Nice to have an extra box, it will make the swap fast. You will be saving so much time you might as well install EFI and 4 link the rear while the heater box is out. poke
Re: Heater box
How do you think I wound up on coilovers? Need to keep a shiny new heater box off the ground somehow.
Re: Heater box
YEP!
There it is!!!!!
(I agree. ;)
sykanr0ng
Re: Heater box
Post by sykanr0ng »
'While I'm at it' is the best way to deal with 'How many times do you want to take it apart?'
Take it apart and change one part and put it back together, take it apart and change one part and put it back together, take it apart and change one part and put it back together, take it apart and change one part and put it back together, take it apart and change one part and put it back together,......................................................
