Various free parts for local pick-up
Best price ever!
Post by Eck »
I have a number of things that I will throw out as free or beer donation accepted.
- upper floor section from passenger side
- ignition module
- 2" aluminum 2 barrel carb spacer
- wiper arms and blades
- Fan blade and fan bracket
- shifter collar and shifter
- I think a couple of throttle linkages
- various v-belt brackets
- harmonic balancer 28oz.
- wiper fluid container and motor (works)
- hubs from my D30 (Phil- let me know if you want these)
- 4* c bushings - in good shape
- v belt pulleys
- mechanical fuel pump - barely used.
- steering column to dash cover - no cracks
- 351 timing chain cover
- air breather and filters
Re: Various free parts for local pick-up
Post by Eck »
Lower steering shaft from 73 auto column with stock power steering. Rag joint and upper rag joint connection included.
Drive shaft-- has the old borg warner yoke in case you need one as a spare.
TOOLMAN
Post by TOOLMAN »
I would be interested in the floor section.
Post by mickphatmac »
PS Pump & brackets!
Please!
pgilbeau
Post by pgilbeau »
I will take the hubs, it will help with what I am doing.
windshield wiper reservoir also please!
Post by Eck »
Jason- floor piece is yours
Phil- hubs are yours (I also found some drums if you want them-- let me know so I can pull them from the dump truck)
Mike-- got yours set aside
pgilbeau
Post by pgilbeau »
Eck wrote:Jason- floor piece is yours
I will take the drums also, thanks
cdj7k
Post by cdj7k »
If still available, i will snag your fuel pump, fan blade and blade mount. Thanks, dave
Post by Kinder »
If the steering shaft & driveshaft are in usable condition IΓÇÖd like them.
Post by Eck »
cdj7k wrote:If still available, i will snag your fuel pump, fan blade and blade mount. Thanks, dave
All yours.
JimGL
Post by JimGL »
Interested in the shift collar and shifter, and wiper arms and blades.
Also interested in throttle linkages, if you have them.
Thanks
Post by Eck »
JimGL wrote:Interested in the shift collar and shifter, and wiper arms and blades.
Thanks
Wipers are gone, but everything else is yours. IΓÇÖm in Wheat Ridge. Shoot me a PM when youΓÇÖd like to come by and get them.
