Christian Radiator
Champion Brand Aluminum Radiators
1966-77 Early Bronco Part #CC521
Ebay Item #270700404473, 280627787433
Top Rated Aluminum Radiators that have a great reputation from a ton of ClassicBroncos.com Forum Members. Extremely high quality. Champion makes a radiator for many different vehicles. Christian Radiator sells these for cheaper than any other source, then discounts the radiators even further for CCB Club Members. Larger discount for Bulk Orders on the Radiators and the decreased Shipping Costs. Out of State so No Sales Tax. Shipped by FedEx and Insurance is Included.
** Must Call David direct and mention that you are a Member of Colorado Classic Broncos Club to receive the maximum discount **
David Chaney
714-655-4356
714-483-5832
dwchaney1@me.com
Item Description:
Champion Cooling Systems radiators are manufactured at their ISO certified facility. They are made to high standards of quality and workmanship using the HIGHEST GRADES of aluminum available and are constructed with 100% WELDED SEAMS, BRAZED CORE TECHNOLOGY AND NO EPOXY They come with a lifetime limited warranty and are made to install without modifications using your original mounts and fan shroud giving you the confidence you desire.
Features:
ΓÇó Champion higher density core: cooling rows are spaced 3/8" apart: giving you 25% more rows within the core than other aluminum radiators sold on eBay and 35% more rows than OEM copper.
ΓÇó Aluminum dissipates heat more efficiently than copper or brass
ΓÇó 14-16 cooling fins per inch (42 per square inch) giving you approximately 1500 more cooling fins than other aluminum radiators and approximately 3000 more than OEM copper radiators
ΓÇó Lighter weight
ΓÇó Outperforms other 2 row aluminum as well as 3 and 4 row copper radiators
ΓÇó High performance appearance
Item Details for #CC521:
Core Dimensions: 19" high x 19 1/4" wide (3 row core)
Overall Dimensions: 21 1/8" High x 26 1/2" wide
Upper inlet: 1 1/2" located on driver side.
Lower outlet: 1 3/4" located on passenger side.
Auto Trans Cooler: Included
OEM mount system
OEM style brass petcock drain.
Billet style fill neck construction - NOT STAMPED
Product Guarantee:
We will refund (or exchange after 60 days) 100% of your money (Including All Shipping Costs) if:
* Your radiator does not fit
* Your radiator does not cool your engine
* Your radiator leaks
* Contains manufactureΓÇÖs defects
* Or for some reason you just do not like it
- Check out the CCB Members Only Vendor Section for Members Only Pricing Information -
Champion Brand Aluminum Radiators from Christian Radiator
- Entourage
- Entourage
Re: Champion Brand Aluminum Radiators from Christian Radiato
I have the CCB Members Only pricing information in the CCB Members Only Vendor Section.
- crawlercreations
Seems like some great pricing! My radiator is still going strong but I may pick one of these up just in case! Thanks for all your time putting it together for all of us!
- Entourage
No Problem - I love discounts and this is a great add at a great price from a great guy!
- Justin
- Entourage
NICE!
