serp swap questions
mustangjonny84
serp swap questions
Post by mustangjonny84 »
The time has come for my serpentine swap. Most of my searches net me something about the Explorer parts and that's just not my cup o' tea. I have some parts leftover from my old fox body Mustang that I'd like to consider.
What I've got leftover:
Fan, fan clutch (near new), water pump pulley, crank pulley, alternator pulley, alternator bracket, and tensioner....all OEM from '84 5.0
What I'm considering for the swap:
P/S pulley from early 90s E150 (because they used the Saginaw with a serp belt)- http://www.rockauto.com/en/moreinfo.php ... 56&jsn=475
Aftermarket alternator bracket- https://www.summitracing.com/parts/sme-2002/overview/
Reverse flow water pump w/ passenger side dump- https://bcbroncos.com/shop/cooling/wate ... ly-bronco/
Here are my questions:
1. Has anyone ever used an alternator bracket like this? I've never been a big fan of that OEM tensioner. But I've also never used a turnbuckle for tension on a serp belt.
2. Regarding the water pump, would this water pump require a different front cover?
3. Also regarding the water pump, it seems that reverse flow with a passenger side dump is a bit of a rarity. Are there any others out there besides the BC unit that I'm just not finding?
Please and thank you in advance for the help. I'm certain I've left something out so fire away with any questions.
1975 Bronco- 302 w/ EFI,NP435,twin stick D20, D44, D60, 4.5" WH lift, 1" body lift, 35" Nitto Trail Grapplers
2012 Flex Ecoboost - VTA mod
2003 Mustang Mach 1- K&N,SSS catback
1992 GMC Bread Van - wife's food truck...The G-Spot
2003 Suzuki SV1000- GSXR fork,Danmoto cans,carbon fiber fender, lots of stuff painted black
1980 CB750 cafe- GSXR fork,K&N,CBR coil packs,Chappell customs seat,MAC 4/1 exhaust
Re: serp swap questions
I'd recommend not running a turn buckle tensioner. A spring tensioner is designed to have some give to it and a good one will provide the proper tension to the belt with out slippage. I have seen many broken cranks over the years in the terminator cobra world from guys running the solid tensioners on the blower belts.
As for water pump you'll need to look at the depth of it. Ford small blocks had many different lengths on the water pumps to line up. Your best bet is to call BC's and ask if it would work for your application. I do believe if you go with a standard mustang serp water pump it does require a timing chain cover change.
As for the explorer set-up it is a lot more compact set-up and shorter too. Allowing more room for a fan and clutch. If you want the Sag pump with explorer serp WH makes a kit for just that. Eck has it on his bronco. I have no issues with the explorer pump running hydroboost and PS turning 35's.
mustangjonny84
Good advice, Zoso. Thank you!
Mitche11
Post by Mitche11 »
Jonny,
I have a complete explorer SERP setup in a box in my shop. I know that you said that you arenΓÇÖt interested in Explorer setup, but with the work and the sourcing that youΓÇÖre setting yourself up for with the mustang options, I just wanted you to know that IΓÇÖd be happy to sell you a complete explorer setup if you want. YouΓÇÖll need to get a power steering hose and change out the timing cover. Sourcing a crank pulley to match your flywheel balance is easy and you know itΓÇÖll all work well. You donΓÇÖt have to worry about which way the waterpump spins, or fabbing up a bunch of stuff to make sure it will physically fit under the hood and give you enough space before the radiator. Anyway, youΓÇÖll have a good time with this project but IΓÇÖm happy to help streamline your path if you want to take a different route. Let me know.
mustangjonny84
Mitchell...it was good to meet you at the last breakfast and thank you again for the offer!!!
I ended up using the alternator bracket from my old fox body with a new tensioner. Wrapped it up (sort of) today and we're mobile once again. I've got one little leak on the bolts on the back side of the Saginaw and then I'll post up some pictures.
Mitche11
Post by Mitche11 »
Johnny,
I just now saw this message. It was great to meet you at that Bronco Breakfast as well! Great group of guys and gals, for sure. I'm glad you gut the setup working. Now onto the next project on the rig eh? Mine is still coming along but it always surprises me how a truck that is running under it's own power can still need 100 hours if tinkering. Fun stuff... as long as I don't go crazy along the way.
