Troubleshooting Speedo/Odometer
ScottBarnes
Post by ScottBarnes »
My speedo has been doing the dance for a while, and that doesn't really bother me. But now, it stopped all together along with my odometer. I NEED my odometer! Both ends of the cable are attached, so not really sure the best way to troubleshoot. Is there a "90% chance it's [this]"?
Also -- where does the "gear" go -- speedo side or transfer case side? and what tooth count do I need w/33" tires and 4:10 gears?
Go Hard or Go Home
cpldavis37
Re: Troubleshooting Speedo/Odometer
Post by cpldavis37 »
You can purchase the gear from Toms, Wild horses, Bronco Hut probably sells them locally.
There is a retaining clip on the transfer case side of the cable that holds the gear on. Check to see if it is still attached. While it's disconnected from the t case you can spin the gear. I did it with a drill. It could also be the speedometer and in that case it could need lubrication, but I am not sure what type (Lithium? Graphite?)
TJ
F. Scott Fitzgerald
ScottBarnes
cpldavis37 wrote:You can purchase the gear from Toms, Wild horses, Bronco Hut probably sells them locally.
Thanks -- I'll try the transfer case side first.
Go Hard or Go Home
Post by Eck »
If you have felt that your speedometer now is pretty close to accurate, I would just look at what color gear and/or count the teeth when you pull it out of the transfer case. Then just order up the same one if you determine the gear is bad. If not, it could be in need of lubricating the speedometer gauge side. Or.... you are screwed and you'll need to remove and have refurbished...
cpldavis37
Here is a pic of a clip and gear.
TJ
F. Scott Fitzgerald
I would think graphite would be best lube as it doesn't collect dust.
Oddly, just cruising on cb.com and saw this:
https://lmr.com/products/Mustang-Speedo ... Calculator
Edit again - I read further down the thread and now I see why that thread popped up! LOL!
ScottBarnes
Eck wrote:.. you are screwed and you'll need to remove and have refurbished...
Yeah, that's not happening before Baja so you'll be the official keeper of the mileage traveled! LOL
Go Hard or Go Home
Post by Viperwolf1 »
I can get you fixed up. I have some Speedo gears. Might need to do minor surgery on the tcase.
ScottBarnes
Viperwolf1 wrote:I can get you fixed up. I have some Speedo gears. Might need to do minor surgery on the tcase.
Thanks -- I'll take a peek in the morning to see if it's something simple. Minor surgery on a tcase is above my pay grade! HAHA...
Go Hard or Go Home
Post by Kinder »
I have a spare nearly new cable if needed, I may also have a gear or two. Let us know what you find when you pull the cable.
Pull the cable out of the tcase. The driven gear will be on the end of it. Look inside the hole that gear came out of. You'll see the drive gear. That gear should be centered in the hole. If it isn't centered it won't turn the driven gear. Make note of the color of the drive gear too. They are either green or blue. The difference is the tooth count, either 6 or 7.
ScottBarnes
its not clocked in a way that I can get a view, but when I stick my finger inside it ΓÇ£feelsΓÇ¥ somewhat centered at the top of the gear. ItΓÇÖs blue. The gear on the speedo cable has some teeth grooved out, which could definitely cause the jumping of the speedo I would think. But itΓÇÖs completely inop now. I pulled the wrong part first and exposed the cable. It spins easily with my fingers - just not sure if thatΓÇÖs spinning all the way to the speedo, but it sounds like it is. Now I canΓÇÖt get that darn clip back on though. ImageImageImage
Go Hard or Go Home
Post by Eck »
IΓÇÖve got one that I tried but threw my speed off so practically brand new. IΓÇÖll bring it tomorrow.
ScottBarnes
Eck wrote:Image
thanks Mike - since IΓÇÖve got it apart, IΓÇÖm going to do a little research and try to get one that matches my tires/gearing because this one was about 10 mph off at 50 mph speed.
Go Hard or Go Home
ScottBarnes
Also - I did confirm the cable to the speedo is ok because I connected it to the drill and moved the needle. Tip for anyone doing that - it spins to the left (counterclockwise). Took me a couple tries to figure that out.
Go Hard or Go Home
ScottBarnes wrote:Also - I did confirm the cable to the speedo is ok because I connected it to the drill and moved the needle. Tip for anyone doing that - it spins to the left (counterclockwise). Took me a couple tries to figure that out.
How many teeth on the red gear? Looks like you need 17 or 18.
ScottBarnes
I counted 16 now, and it's off for sure. I'm running 33's w/4:11's. Any tips for getting that stupid clip back in that holds the cable into that adapter? Also -- based on the pics, are you thinking a new gear will resolve this issue?
Go Hard or Go Home
ScottBarnes wrote:I counted 16 now, and it's off for sure. I'm running 33's w/4:11's. Any tips for getting that stupid clip back in that holds the cable into that adapter? Also -- based on the pics, are you thinking a new gear will resolve this issue?
Looks like you need to push the black plastic into the aluminium piece some more to expose the slots.
Yes, I think a new gear will do it.
I have an 18 tooth gear. Your speedometer must have been reading fast with the 16?
ScottBarnes
Viperwolf1 wrote:I have an 18 tooth gear. Your speedometer must have been reading fast with the 16?
Awesome! I'll txt you and figure out a way to get it. Yes, it was reading fast. I mis-stated above - had it backwards.
Go Hard or Go Home
ScottBarnes
New gear got my odometer rolling again. 18 tooth (thx Phil!) has my speedo reading 50 when actual speed is 40 (based on gps phone app). IΓÇÖm wondering if my terra lows have something to do with this? I honestly donΓÇÖt care much about that, though. My odometer is working and thatΓÇÖs the big deal. Thx for the help.
Go Hard or Go Home
Post by Eck »
ScottBarnes wrote:New gear got my odometer rolling again. 18 tooth (thx Phil!) has my speedo reading 50 when actual speed is 40 (based on gps phone app). IΓÇÖm wondering if my terra lows have something to do with this? I honestly donΓÇÖt care much about that, though. My odometer is working and thatΓÇÖs the big deal. Thx for the help.
Yah but your odometer will move 10 mph faster meaning you are putting a lot more miles on your odometer than you are actually going (so whether you are using it to track actual distance or to keep track of how many miles are on your Bronco for things like value, etc.) you will be way off...
No, you're tera low shouldn't affect it as I am certain in 2WD or 4Hi, it's still 1:1. You're still 20% off. Corrected by another speedo gear, tire size, or axle gears. In order of expense.
It's actually 25% fast. That is very unusual. We can swap to a 21 tooth gear but that is probably not even enough teeth. 6% per tooth. You should check the accuracy of the odometer. It is separate from the speedometer and it may be more accurate for the 18 tooth gear. The speedo could have a problem with the magnet.
ScottBarnes
got it - IΓÇÖll test odometer tomorrow - thx
Go Hard or Go Home
