Back seat pondering
J.Medina
Back seat pondering
So I have a 68 half cab, the body work is getting done right now. I made the decision to make the bulkhead a permanent installation, but I'm wondering how my decision effects the back seat. Is it going to be a pain for people to get back there? Would it make sense to turn the seat around and have it facing backwards? Can I turn the seat around without modification?
Sent from my SM-G950U using Tapatalk
J.Medina
Re: Back seat pondering
Oh I have a full cab for it as well, it is kinda a crossbreed.J.Medina wrote:So I have a 68 half cab, the body work is getting done right now. I made the decision to make the bulkhead a permanent installation, but I'm wondering how my decision effects the back seat. Is it going to be a pain for people to get back there? Would it make sense to turn the seat around and have it facing backwards? Can I turn the seat around without modification?
- Eck
So are you wanting to put a backseat in the back of a half cab or are you wanting to put a full hard top on a half cab and keep the bulkhead in as a permanent install?
J.Medina
Put a full hard top on a half can and keep the bulkhead permanent
J.Medina
Also the mounting holes are existing and in the stock location for the back seat
- Gunnibronco
From the factory, full cab trucks with a bulkhead only came with no rear seat. I don't think getting to the rear seat will be easy at all with a bulkhead. I haven't ever seen a rear seat turned backwards, but I think it will be closer to the tailgate, with a gap between the bulkhead & the rear bench.
J.Medina
Possibly I had a 88 Lincoln town car limo that I turned the middle seat around and it worked pretty good, but not sure with bronco.
- D&D72
Getting in and out of the back through the front is already a PITA. But, not so much for kiddos. Do you have a rear seat to play with positioning? I agree with Gunni, it will be close to the tailgate. post pics if you do this.
J.Medina
Its gonna be a while before I make it home I'm thinking December, but when I get home I'll check.D&D72 wrote:Getting in and out of the back through the front is already a PITA. But, not so much for kiddos. Do you have a rear seat to play with positioning? I agree with Gunni, it will be close to the tailgate. post pics if you do this.
- BOBS 2 68S
I mounted the rear seat backwards years ago, took the top off and went to drive in movies.
J.Medina
Well details?BOBS 2 68S wrote:I mounted the rear seat backwards years ago, took the top off and went to drive in movies.
J.Medina
Like was there any leg room? general fit? would it be easier to get in and out with a full top on?J.Medina wrote:Well details?BOBS 2 68S wrote:I mounted the rear seat backwards years ago, took the top off and went to drive in movies.
- Jesus_man
As others have said, I don't think you can use the factory mounting holes/seat belts tie-ins. I don't know why it couldn't be done, but it'll take some re-engineering.
- BOBS 2 68S
I dropped the tail gate. It was a good idea at the time but if I remember right it was not a big success. Never tried it with the top on.
