Engine Woes
Bronco1294
Engine Woes
Post by Bronco1294 »
Engine Woes! My stock 302/2bbl is cramping out. Main bearings are down to the copper. HereΓÇÖs the problem- IΓÇÖm broke.
I donΓÇÖt need/canΓÇÖt afford a coyote. ItΓÇÖs a 75, driver- camping at high altitude, some wheeling, occasionally pulling my ATV or pop up. Looking at budget-friendly options and I need some feedback. Suggestions appreciated- or cheap 351ΓÇÖs...:)
In Elizabeth, CO in case anyone knows of any deals locally. I canΓÇÖt drop 3-5k on this. Looking for creative ideas. Also- IΓÇÖm not doing the work. Replacing a motor is out of my skill set and existing tool/garage capacity. TIA for any ideas or leads!
Re: Engine Woes
Post by landshark »
I would surf Craigslist for a running 302 and do a direct swap. Might be the easiest and quickest fix.
Re: Engine Woes
Post by Digger »
Avoid the 351 if you're on a budget. Little details like exhaust mods and the like will nickel and dime you.
Re: Engine Woes
Post by Viperwolf1 »
How about a relatively low mile (144K) 99 explorer 5.0 that runs great? No efi or serpentine drive. $200 if you can wait a month. You can see it run up until that time.
ScottBarnes
Re: Engine Woes
Post by ScottBarnes »
ThatΓÇÖs the ticket, right there![emoji1312][emoji1312]
Go Hard or Go Home
cravenbronco
Re: Engine Woes
Post by cravenbronco »
Ditto
ScottBarnes
Re: Engine Woes
Viperwolf1 wrote:How about a relatively low mile (144K) 99 explorer 5.0 that runs great? No efi or serpentine drive. $200 if you can wait a month. You can see it run up until that time.
Hey Phil - all his stuff (intake, timing cover, water pump, PS and ALT brackets etc)should bolt up, correct? What about the balancer and flywheel? IΓÇÖm thinking this is a slam dunk option,right? His Bell housing bolts up, right?
Go Hard or Go Home
Re: Engine Woes
He would need to add his old timing cover, accessories and intake. He will need to get a 50 oz-in balancer. The 5.0 flexplate will work with a C4 as long as he has the 11 7/16" bolt pattern on the converter. The explorer exhaust manifolds are reported to work well in a Bronco. Everything will bolt on.
Bronco1294
Re: Engine Woes
Wow- thanks for all the input! This seems like a good option- where are you located?
Re: Engine Woes
Greeley.
I also forgot you will need a steel distributor gear.
cravenbronco
Re: Engine Woes
Viperwolf1 wrote:Greeley.
I have one if needed
