Bushing for door lock rod
ScottBarnes
Post by ScottBarnes »
Does anyone have a couple of these little plastic bushings that I can pick up today? Changing out my door locks and, of course, new .02 bushings for the rods ImagewerenΓÇÖt included with the new locks. Mine fell apart trying to remove them for reuse. Call or text if you can help. Thx 972-816-1108
Go Hard or Go Home
Re: Bushing for door lock rod
Post by Viperwolf1 »
Parts stores have similar plastic locks in the help section.
ScottBarnes
Viperwolf1 wrote:Parts stores have similar plastic locks in the help section.
good call - didnΓÇÖt even think about that!
Go Hard or Go Home
cravenbronco
Post by cravenbronco »
Did you find some ?
ScottBarnes
Did you find some ?
yep - autozone came thru! Thx! Also had to swap one of the levers on the new ones because L/R are different, but not a big deal. I just wish the stuff you order from these dang vendors was ready to go. Even the smallest little projects like this turn into hrs because the stuff they sell is only about 90%.
Go Hard or Go Home
Post by landshark »
Bronco hut sells all those little pieces as well
I know you are under a time crunch, but I wonder what said vendor would say if you contacted them about the issue. I'm with you, these parts should be RTR!
