Ring and Pinion opinions
- ScottBarnes
IΓÇÖve got to replace the R&P in my 9ΓÇ¥. Any opinions on brand? I assumed I would go with Yukon, but for no particular reason. Thought I would throw it out there for feedback.
Go Hard or Go Home
- crawlercreations
Re: Ring and Pinion opinions
This thread just got bumped today: http://www.pirate4x4.com/forum/general- ... and-3.html
The chart halfway down the page is claiming Spicer gears to be far and away the best. Then a couple others better than Yukon. Having seen that; I've installed a heck of a lot of ring and pinions and I've always liked the pattern I've gotten from the Yukon gears. I've never gotten a noisy set from any manufacturer and I've never seen a failure in my gear installs. I just installed Yukon cheapies(USA standard) in the rear of my pickup truck and Dorman gears in the front. I haven't put it in 4wd to listen to the front gears but the rears are quiet and I got a good pattern on both gear sets. In my latest bronco craziness I've got Richmond gears in the front(only thing offered for a true hi9) and I installed Yukon gears in the rear 3rd. Both sets look well made and have nice patterns.
- ScottBarnes
crawlercreations wrote:This thread just got bumped today: http://www.pirate4x4.com/forum/general- ... and-3.html
Terrific -- that's what I was looking for. Is there a good source for Yukon gears here in the area? Looking for 31 spline 4:11's. Thanks much!
Go Hard or Go Home
- ZOSO
- Moderator
I just put usa standards in my bronco. Only have a 100 miles or so on the rear but they are quiet. The fronts havent been under power but hubs locked (on coast side) they are quiet.
- Kinder
Western Driveline in Aurora is a distributor, not sure what they sell them for, last set I purchased was online.
- TOOLMAN
ScottBarnes wrote:Terrific -- that's what I was looking for. Is there a good source for Yukon gears here in the area? Looking for 31 spline 4:11's. Thanks much!
I don't think the spline count matters when replacing the gear and pinion. But I would probably replace all the bearings while you're in there. I think I bought a bearing kit with the solid pinion spacer from Iowa and it ended up being Yukon bits anyway. http://www.quickperformance.com/Ford-9-Master-Bearing--Install-Kit-Timken-USA_p_13.html
- Jesus_man
TOOLMAN wrote:I don't think the spline count matters when replacing the gear and pinion.
It does. The splines have to match the axle shafts. But you bring up a valid point...install kit!
- ZOSO
- Moderator
Jesus_man wrote:TOOLMAN wrote:I don't think the spline count matters when replacing the gear and pinion.
For just a ring and pinion spline count doesn't matter. Since you don't have the carrier break in a 9in you can keep it and run any gear you want.
- TOOLMAN
ZOSO wrote:Jesus_man wrote:TOOLMAN wrote:I don't think the spline count matters when replacing the gear and pinion.
Thanks Rob...you beat me to it!
- Jesus_man
Oh wow! Where is my head!! I stand corrected!
- Viperwolf1
You definitely need to replace bearings. There was a lot of metal in the oil.
- ScottBarnes
Viperwolf1 wrote:You definitely need to replace bearings. There was a lot of metal in the oil.
Used my WH gift certificate for a rebuild kit that includes all the bearings! LOL
Go Hard or Go Home
- Gunnibronco
I don't see a chart. What am I missing? Should it be in post #67? Looks like an 'attached image' is missing for me.
I had a set of USA Standard installed in my F250, they went in fine and seem to be performing well. Even if they were 'noisy' I'm not sure you'd hear it over the 7.3. I guess if you did, you'd know they were really bad.
