Throttle Body Position
- Strike2
I have a 96 Explorer EFI set up and was checking clearance for the throttle body and the hood will not close in the OEM position (pic1) is there any reason that I shouldn't rotate it 180 degrees? (pic 2).
- Viperwolf1
Re: Throttle Body Position
You can rotate it.
- Strike2
Great news! Thanks for the reply
- D&D72
I took that EGR stuff off of mine and ran the throttle body straight off the riser/plenum.
- Strike2
D&D72 wrote:I took that EGR stuff off of mine and ran the throttle body straight off the riser/plenum.
Well that looks much cleaner, Thanks for the letting me know I think that set up will fit much better
- mickphatmac
I have a non-egr lower inake that you can have along with the upper intake it you want it?
I need an aux tank skid plate???
- Strike2
mickphatmac wrote:I have a non-egr lower inake that you can have along with the upper intake it you want it?
Is a non-egr lower any benefit to the 96 I have?? I think I might have a aux tank skid plate or main skid plate its been awhile since I looked at my pile . Ill text you later once I get home.
- landshark
The one with an EGR has a hole in the center of the lower that you should plug. I tapped and screwed a pipe plug in it. The ones without an EGR donΓÇÖt have the hole.
- mickphatmac
My lower intake has NO HOLE to plug.
I don't know about the EGR from beans!?!?
...but definitely 1 more electronic thingy you can DELETE!
