speedometer woes.
speedometer woes.
With my recent regear my speedometer is now fast. By about 18%. So doing the math I's need a 24 tooth driven gear. Well they only make a 21 max. Current is 20teeth. Not sure what the drive gear tooth count is. Any ideas on how to correct it with out buying a new digital cluster?
Re: speedometer woes.
Post by Digger »
Bigger tires?
Post by landshark »
Phone GPS/Speedo?
Post by Viperwolf1 »
Replace the speedo drive gear on the output shaft with a 6 tooth version.
Viperwolf1 wrote:Replace the speedo drive gear on the output shaft with a 6 tooth version.
Have one laying around?
Probably do.
I'll trade ya if you do.
Let's make sure you have a 7 first. What color is the gear?
Viperwolf1 wrote:Let's make sure you have a 7 first. What color is the gear?
Blue
Blue
Got a green 6 tooth one. Come get it while it's hot, out.Image
Phil I'll give you a call Monday and can run up then. Gotta stick around to this side of town as I have the electronic leash until then.
