74 Baja Race Bronco - Baja or Bust
- landshark
So some of you know that I have decided to race in the 2019 NORRA Mexican 1000 and now that i have decided a direction and Bronco to build I thought I woudl start this thread to document my progress and hopefully garner some interest to help out, be apart of the chase team and more. I don't have all the fine details sorted just yet, as it took me a few months to figure out exactly the way forward for the build. Essentially after discussing with several members of this forum and family it seemed a bit short sighted to tear my running and driving 72 apart - literally, instead of passing it on to the next person to enjoy as a daily driver or a great starter for a build. In place of it, buy a roller and build that into my baja rig.. so that's what I did.. or at least the buy a roller part so far.
This is the 72 that I will be selling -
and here is the 74 that followed me home today - no running gear, Dana44 front. Yes of course there is some rust - will repair most of it.
found a horseshoe under the seat
- landshark
Re: 74 Baja Race Bronco - Baja or Bust
progress tonight, rust looks worse than it is... lots of surface, lots of fred flinstone
tomorrow I will continue to strip stuff off and have a good look at what needs to be repaired!
- phyler
- CCB Admin
Oh, this should be a great thread. I was very jealous over the Baja trip. This will be great to follow. Happy to lend a hand when needed.
OG
OG
- Kinder
IΓÇÖd like to donate some parts if you are interested, letΓÇÖs talk over the phone then meet at my storage. Also, do you have a pit crew together?
- Strike2
This is totally cool! Congrats of starting the journey
IΓÇÖll be following the build for sure
,the horseshoe is a great sign and needs to be kept with the Bronco imo
,the horseshoe is a great sign and needs to be kept with the Bronco imo- Jesus_man
Oh man, this is going to be great!! So what are your overview plans? Suspension, power etc??
pgilbeau
Definitely interested to follow this build as I have thought about the NORRA thing after seeing Brad and Roger Lovell run their Bronco. Any idea on what class your going to run?
- landshark
Kinder wrote:IΓÇÖd like to donate some parts if you are interested, letΓÇÖs talk over the phone then meet at my storage. Also, do you have a pit crew together?
No pit crew yet, just trying to get my crap together and get the ball rolling first. ideally it would great to have 3-4 people in a chase truck/trailer.
I will give you a call this week. Unfortunately I am at a customer site all day every day for at least a week, maybe two so unable to do anything during the day at the moment. Nice thing is there is lots of patching to do in the mean time!
- landshark
Jesus_man wrote:Oh man, this is going to be great!! So what are your overview plans? Suspension, power etc??
Basics are 351W (still talking to the engine builder on stroker or not), C4 with manual reverse valve body, Dana20 hardened output shaft/tail housing, 1350 rear drive shaft, 9" big bearing trussed housing with full spool, 4.56 gears, 33" tires 15" rims, 2.5" lift, no body lift, 2" Fox shocks at all 4 corners, coils and leafs, custom cage, 33 Gallon fuel cell etc etc etc.
pgilbeau wrote:Definitely interested to follow this build as I have thought about the NORRA thing after seeing Brad and Roger Lovell run their Bronco. Any idea on what class your going to run?
I will be running in the Pioneer class which is the same class as the baja bronco - mark and Toddz and the 69 bronco driven by Boyd Jaynes and Brian Godfrey , basically the rules are stockish suspension points, 35" tires or smaller, rear leafs, nothing mroe fancy than a 2" reservoir shock, anything goes as long as it was available during the years the body style was produced.
- landshark
Finished stripping the inside and engine bay, will move on to removing the fuel tanks, ebrake and all the other stuff I won't need or needs replaced.
No big surprises as far as rust repair is concerned, a little disappointed in the amount of rot in the drivers side cowl, not an easy patch but I have done it before. I think i can salvage enough of the door post to replace just the back cover, will know when i cut stuff away.
Engine bay is straight forward, both side skirts, I am thinking i will just replace the entire driver side kick panel as i already have it.
Both floor pans are long long gone, matter of fact the floor mat was resting on top of the aux fuel tank, you could fred flinstone this thing easy. Will also be doing some quick patching to the rear bed in the corners and along the wheel well. This will never be restored so not going to be anal retentive about the patches or welds - must resist!
Checked the fuel cell fitment - ready to roll!
and of course my helper for the day, always there for encouragement and advice. I think he's telling me i have a better chance of being a quarterback than getting this thing ready in time!
- Gunnibronco
Good luck with this Chris! Looking forward to seeing this all come together.
- landshark
I will be working on this junk all weekend. If any of you want to swing by please do. Most of you have my details and locations. Will be cutting and welding.
- landshark
Did some work this weekend. Should have the front passenger side floor pans and other patches welded in by tue night. Will then move to the drivers side which is going to be a bear.
Mr. Lav
Looking good.
pgilbeau
Looks like your making some good progress, keep it up.
- Rox Crusher
Will this rig be capable of a run up pikes peak against Aaron Kaufman next year ?
- landshark
Rox Crusher wrote:Will this rig be capable of a run up pikes peak against Aaron Kaufman next year ?
You bet!
Speaking of which I will be pushing hard next week to finish sheet metal patching, so if anyone gets ants in their pants to have some cutting/welding fun let me know and swing by. Will be working most evenings and expect all weekend after Monday.
- Jesus_man
I so wish I could come help and learn some body work from you!!
- landshark
Things are starting to show up, better get my butt in gear!
Reverse gate will replace the standard pattern, itΓÇÖs on the way.
- Viperwolf1
Lots of things appearing.
- Jesus_man
Time to turn some wrenches!
cravenbronco
Sweet
Can't wait to see the end result
- landshark
Driver floor pan in. Kick panel and door post will be in tomorrow. Need to repair cowl a little then moving to the bed area repair.
- landshark
Body panel Replacements done, will tackle more body work later. on to the fun stuff. Will pull the body off this week and start reinforcing the frame and building suspension.
- Jesus_man
That is a lot of coolness!!
I've always wanted one of those pinion guards.
- Justin
Ruffstuff currently has them on sale.
- landshark
Sprayed primer and seam sealed most of the repairs, built a rolling stand for the body. Rear disk brake kit came in.
- cw72
Nice looking disc kit. I have a similar style on my 14b, but IΓÇÖve been having problems with those calipers seizing up after what seems a season of use. Going to be swapping in these next go around, hopefully better luck and more stopping power while IΓÇÖm at it. https://www.wilwood.com/calipers/Calipe ... l%20Piston
- crawlercreations
cw72 wrote:Nice looking disc kit. I have a similar style on my 14b, but IΓÇÖve been having problems with those calipers seizing up after what seems a season of use. Going to be swapping in these next go around, hopefully better luck and more stopping power while IΓÇÖm at it. https://www.wilwood.com/calipers/Calipe ... l%20Piston
I have those calipers front and rear on my bronco. I can't directly compare them to the standard calipers but I will say I can lock up all 4 40" tires more easily than should be with manual brakes. Lightweight and well built.
- landshark
We will see how this kit does, itΓÇÖs the ruff stuff early bronco kit. I didnΓÇÖt want bolt on and this one seems decently built and priced better than most.
