leftovers
D&D72
leftovers
Post by D&D72 »
best offer on all items
Re: leftovers
John is that an auto column?
pgilbeau
Re: leftovers
Post by pgilbeau »
Looks like a 3 speed column to me, you can see the shift levers at the bottom. If its a 3 speed I may be interested.
Re: leftovers
Post by landshark »
Interested in master cylinder and aftermarket wheel. WhatΓÇÖs the master cylinder for? Looking for manual
D&D72
Re: leftovers
Post by D&D72 »
landshark wrote:Interested in master cylinder and aftermarket wheel. WhatΓÇÖs the master cylinder for? Looking for manual
Master cylinder is manual drums. wheel is free everything but the horn button...
D&D72
Re: leftovers
Post by D&D72 »
pgilbeau wrote:Looks like a 3 speed column to me, you can see the shift levers at the bottom. If its a 3 speed I may be interested.
Philip you are correct. however, the PO swapped the shift collar on it.
Re: leftovers
Post by landshark »
I think both might work. IΓÇÖll take em
D&D72
Re: leftovers
Post by D&D72 »
ok so, what you offering?
Re: leftovers
Chris, you after the steering wheel alone (top pic) or the column?
cpldavis37
Re: leftovers
Post by cpldavis37 »
Is that an AUX filler neck? If so how much?
TJ
F. Scott Fitzgerald
D&D72
Re: leftovers
Post by D&D72 »
cpldavis37 wrote:Is that an AUX filler neck? If so how much?
Yes TJ, 20?
Mr. Lav
Re: leftovers
Post by Mr. Lav »
Is the steering column available?
D&D72
Re: leftovers
Post by D&D72 »
Mr. Lav wrote:Is the steering column available?
Yep
Mr. Lav
Re: leftovers
Post by Mr. Lav »
Pm
cpldavis37
Re: leftovers
A bargain at half the price. I'll take it.
TJ
F. Scott Fitzgerald
Re: leftovers
Post by landshark »
Steering wheel only.
D&D72
Re: leftovers
Post by D&D72 »
landshark wrote:Steering wheel only.
come get it thumbs up
Re: leftovers
Post by landshark »
Will do, maybe this week sometime if your around? I will pm you.
