75 Bronco Parts Purge
Strike2
Post by Strike2 »
I'm at the point on my build where I will no longer be needing the parts listed below all parts are off a 1975 Bronco 302 with 137K.
Parts are located for local pick up in Frederick CO. Will post pictures during the day.
Thanks
Steve
Rear Leaf Spring 20.00
302 Air Filter 20.00
302 Exhaust heat shield 10.00
(SOLD to kbank6) Passenger side inner wheel well 20.00
(SOLD to kbanks6) Driver side inner wheel well 20.00
(SOLD to FRIDAY)Transfer case skid plate 10.00
(SOLD to FRIDAY) Radius arm set 40.00
Front bumper minus the license bracket 30.00
Front license bracket 20.00
Rear bumper w/Ford stamped hitch 30.00
(SOLD to LA HI)302 radiator 20.00 (need flushed/cleaned no leaks)
(SOLD TO LA HI)302 radiator shroud 20.00
(SOLD)fuel tank transfer switch 20.00
(SOLD)front fuel tank tube 10.00
(SOLD)rear fuel tanks tube 10.00
Front springs 10.00
302 heads 20.00
exhaust manifolds 20.00
Power steering pump 20.00
302 intake manifold 20.00
electronic distributor 20.00
2-barrel carb 20.00 ( needs rebuilt)
(SOLD TO LA HI) 6-blade radiator fan blade 20.00
OEM jack and lug wrench 20.00
Steering wheel 20.00
Strike2
Re: 75 Bronco Parts Purge
Post by Strike2 »
Parts pictures
Strike2
Post by Strike2 »
More Pics
Strike2
Post by Strike2 »
more
Strike2
Post by Strike2 »
more
Strike2
Post by Strike2 »
more
Strike2
Post by Strike2 »
last ones
Sorry no pic of the jack parts today
Post by landshark »
DonΓÇÖt know if you care but that license plate mount for the front bumper is worth $40 or so. They are slightly rare.
Strike2
Post by Strike2 »
landshark wrote:DonΓÇÖt know if you care but that license plate mount for the front bumper is worth $40 or so. They are slightly rare.
I appreciate the head up! I'll separate it and ask 20.00
Friday
VENDOR
VENDOR
Post by Friday »
I'll take the radius arms and the transfer case skid plate if still available.
Strike2
Post by Strike2 »
Friday wrote:I'll take the radius arms and the transfer case skid plate if still available.
There yours
kbank6
Post by kbank6 »
IΓÇÖll take both wheel wells if available.
Strike2
Post by Strike2 »
Hey kbank6
The wheel wheels are still available. Pm sent
reallytallman
Post by reallytallman »
any parts still available, interested in the radiator and jack specifically
Strike2
Post by Strike2 »
Hey reallytallman,
The radiator is sold, but I'm sure I have the jack somewhere in the garage lol. I'll check when I get home
EBsaver
Post by EBsaver »
Is the power steering pump still good? Is it the same as a ΓÇÿ73? MineΓÇÖs leaking pretty bad
Strike2
Post by Strike2 »
Hey EBsaver,
sorry for the delay reply I was in AZ for a week and out of the loop. I'm pretty sure its good but not sure if 73 -75 are the same ?
I'll sent you a PM
