Chevy blower motor issues
B.O.B.
Post by B.O.B. »
I did the swap and had to put a spacer between the motor and the heater box to keep the cage hitting the back side. Problem is I keep popping fuses. Have the motor grounded to the dash and it is getting power from the original wiring. Is there anything I should be looking at? I also blocked off the fresh air hose from the outside and ditched the box. Anybody ever try to put a pusher fan on the outside to push more air in?
la hi
Re: Chevy blower motor issues
Post by la hi »
GROUND, GROUND, GROUND, then a heavier wire from the power source to the heater motor!!
Post by Gunnibronco »
Mine was actually melting the solder inside the fuse, without blowing the fuse. It was an original harness & there was light rust on the contacts where the fuse snapped into the box. Cleaned up the contacts with some sandpaper and the problem was solved.
la hi
Post by la hi »
Good job!
Post by Kinder »
WillemΓÇÖs was/is doing the same, plan is to replace the heater blower circuit with non 50 yo parts.
Post by Viperwolf1 »
Gunnibronco wrote:Mine was actually melting the solder inside the fuse, without blowing the fuse. It was an original harness & there was light rust on the contacts where the fuse snapped into the box. Cleaned up the contacts with some sandpaper and the problem was solved.
This is a common problem and is the result of the fuse contacts getting hot enough to melt solder. I replaced my fuse with a circuit breaker of the same rating and all is good.
You can find circuit breakers that fit in many '60s and '70s land yachts in the wrecking yards.
B.O.B.
Post by B.O.B. »
Where is exactly would I put this breaker? Before the resistor, after, before the fuse?
B.O.B. wrote:Where is exactly would I put this breaker? Before the resistor, after, before the fuse?
In place of the fuse. They are available in many current ratings. You want the 20 amp version.
B.O.B.
Post by B.O.B. »
Found the issue. My ECU came loose and was hitting the resistor causing it to short out. Luckily nothing was damaged. Working great now just need to change the thermostat.
